It is currently Fri Jan 02, 2026 12:24 pm
PostPosted: Wed Oct 22, 2014 9:29 am
Hey guys i recently changed the springs on my distributor and ive had the hardest time to install my distributor back, because i cant get the dizzy to 10-19 btdc it jumps way to much when i try to atleast move one tooth. I either get 0-10 ATDC or 20-45 BTDC i got it to run at 20 btdc and thats after i drilled in to the distributor adjustment thing so i can move the distributor a bit. Any help??
1970 Dart Swinger Matching Numbers..
PostPosted: Wed Oct 22, 2014 10:18 am
Are you using both adjustments slots...?
(there is an adjustment slot on the top and another on the bottom)
Does your distributor have the adjuster on the bottom like the one pictured in this post, http://slantsix.org/forum/viewtopic.php?t=56335
Mattelderca
PostPosted: Wed Oct 22, 2014 10:27 am
Just the Bottom.. wait theres two adjustment slots? i just use the slolt where the bolt connects the dizzy to the engine block wheres the other one?<a href="http://s42.photobucket.com/user/Dante_Espinola/media/dist-wrench_zps37706d25.jpg.html" target="_blank"><img src="http://i42.photobucket.com/albums/e336/Dante_Espinola/dist-wrench_zps37706d25.jpg" border="0" alt="dizzy photo dist-wrench_zps37706d25.jpg"/></a>[/img]
PostPosted: Wed Oct 22, 2014 11:26 am
Look at the opposite side of the plate. You'll see another bolt that goes through the plate (and the second slot) that threads into the distributor body. Perhaps yours loosened up in the process. You can see it in the pic with the washer under it.
PostPosted: Wed Oct 22, 2014 10:30 pm
Thank you guys!! The second adjustment completely worked!!!!!!!!!!!!!!
Users browsing this forum: Ahrefs [Bot] and 16 guests
