It is currently Fri May 08, 2026 3:52 pm
PostPosted: Fri Oct 31, 2014 9:14 am
Working on rebuilding the 8 1/4 rear axle in my brother's Duster. The FSM talks about measuring and setting the pinion bearing preload but does not discuss exactly what this is or how to measure it.
My best guess is that I use an inch-pound bar-style torque wrench to measure the drag/torque required to rotate the pinion gear in the housing. Is that correct/accurate?
If so, does anyone have any suggestion, other than a series of adapters, of how to connect a 1/4 inch drive torque wrench to a 1/2 inch drive socket for the pinion nut and still get accurate inch-pound torque readings?
Thanks.
PostPosted: Fri Oct 31, 2014 10:00 am
6 Pack Dart
Yes that is correct.
Ridhard
That exactly how you do it you need an inch pound torque wrench that will read single inch pounds most go from 0 to 25 inch pounds.
Brian
63 Plymouth Valiant Wagon
PostPosted: Fri Oct 31, 2014 11:26 am
You use a "beam type" or "dial type" inch-pound torque wrench (not a click type)- I use two socket drive adapters stacked together- a 1/4" TO 3/8" & a 3/8" to 1/2".
(hello, Mr ToolGuy? I need a 1-1/4" socket, yeah, in 1/4" drive. :lol: )
If you're setting up a new crush collar on the pinion bearing, the fun part is "sneaking up" on the correct amount of preload. You have near zero rotational torque on the bearing until the collar crushes & actually allows the bearings to contact the races- it can take over 150 ft-lbs on the pinion nut to do this. Once you start to have any significant preload drag, it takes very little additional tightening (degrees of rotation) on the nut before you achieve or exceed your preload spec. If you go too far you have to tear it about & use a new collar.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Oct 31, 2014 11:53 am
Thanks guys! Glad I figured it out. I have the "beam-type" inch pound gauge that goes up to something like 25.
I need to check on the drive size adapters I have and probably buy a couple.
PostPosted: Fri Oct 31, 2014 2:31 pm
How assembled does the rear axle need to be when I measure the preload? Fully assebled? Just the ring and pinion assembled?
Thanks.
PostPosted: Fri Oct 31, 2014 3:34 pm
I've hooked up spring scales to a wrench..........
PostPosted: Fri Oct 31, 2014 7:49 pm
6 Pack Dart
"How assembled does the rear axle need to be when I measure the preload? Fully assebled? Just the ring and pinion assembled?"
Just pinion, no ring gear.
Richard
PostPosted: Fri Oct 31, 2014 8:00 pm
Thanks!
PostPosted: Sat Nov 01, 2014 5:09 am
Reed
I am getting set up to do a re build on an 8.75 center section,
from what I have read - see on you tube
for pinion bearing preload,, that is correct,, just the pinion gear
to get a value for carrier bearing preload,, you would have the entire diff assembled, use the same inch lb checking method, and account for the already obtained pinion gear preload and the effect of the gear torque mutplication.
Did you change out carrier and pinion bearings and races ?
If so,, how did you get the bearing assemblied back on, press em on, or heat ? What about the races?
PostPosted: Sat Nov 01, 2014 10:18 am
"I've hooked up spring scales to a wrench.........."
That is exactly what torque is: measure inches (center-to center), apply force measured on your spring scale (fish scale) and do the math (multiply). It doesn't get any simpler than that. My fish scale is a great tool for torques in tight spots. Incidentally, I had a calibration lab check it once just for laughs- It was one pound off at 50 lbs. That's 2% error. You can check your scale by picking up a known weight (bag of flour?) and checking the reading on the scale. :)
PostPosted: Sat Nov 01, 2014 11:51 am
Reed
Note that I am working on an 8 1/4, not an 8 3/4. I dont know if you caught that or not.
I have discovered that I don't have the tools required to properly remove the old bearings from the carrier unit, so I am going to be kind of stupid and cross my fingers and assembe the axle using the old bearings that are on the carrier and pinion that I got form the junkyard. If i am lucky, all will be well. If I am not lucky I have a full rebuild kit that I can drop off at the shop I will pay to rebuild the rear axle and install the new bearings and races. Some things are ust beter left to the professionals for have the right tools to do the job.
PostPosted: Sat Nov 01, 2014 4:25 pm
Yep, saw that you were doing an 8.25,, but I think pinion and carrier bearing install would be about the same as an 8.75, concerning re using, if the races and rollers look good, no piting,,, they are, I saw a different post where you were wanting to pull the pinion, so I thought you were taking the diff apart.
PostPosted: Sat Nov 01, 2014 4:56 pm
Yes, I am pulling the pinion. On the 8 1/4, the pinion gear is pressed into the snout of the center of the axle housing and held in place with the pinion nut in the u-joint yoke. Only the ring gear comes out with the carrier. The carrier drops out the back of the housing leaving the pinion in the front.
I am switching carriers as well as ring and pinion gears, so I am going to chance not disasembling the used carrier I am installing. If it works, cool beans. If it doesn't, I have all the parts to rebuild it to give to the shop that will rebuild it for me.
PostPosted: Mon Nov 10, 2014 8:46 pm
Some things are just better left to the professionals who have the right tools to do the job.
Until they rebuild it twice, it howls worse than before they started, and you're out $800... I'll be spending the money on the tools to do it myself next time.
