It is currently Mon Feb 24, 2025 9:14 am
PostPosted: Wed Nov 05, 2014 2:09 pm
thought it was amid 1980's hydraulic but it has hourglass solid lifters
http://smg.photobucket.com/user/jonwisper/library/slant
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Nov 05, 2014 3:53 pm
Poser
Just a quick glance at the head #'s would suggest 75 - 76.
PostPosted: Wed Nov 05, 2014 5:42 pm
If that is the factory black paint on the head and block then they are both post-82 units. If someone has repainted them then the closest I can tell you from those photos they are post 75 (or whenever the peanut plug head came into use, I always for get the eact year).
Have you checked the part numbers in the matrix?
PostPosted: Fri Nov 07, 2014 5:43 pm
look on the inet but no good luck as yet.
slant six's RULE!
 Post subject: Rlmao...
PostPosted: Fri Nov 07, 2014 6:03 pm
funny...I put that head part number into the search on the board and got a post I added to help the engine/parts metrix...
http://www.slantsix.org/forum/viewtopic ... ht=4027600
 Post subject: ok
PostPosted: Sat Nov 08, 2014 7:09 am
thanks dusteridiot the head came off the block, is that the same era stamped block 1975-1976 with a forged crank. trying down exactly what we have .
slant six's RULE!
Users browsing this forum: Google [Bot] and 65 guests
