It is currently Fri Nov 13, 2026 1:00 pm
 Post subject: This isn't right
PostPosted: Thu May 07, 2015 4:31 am
The throttle lever feel into the trans easy fix to pop it back out. Then while playing with the shifter (no fluid) i heard it pop like its suppose to then it was a quitter pop and less restraint and the 4th time moving it around it was a though spot now won’t move any. Not trying to break anything
PostPosted: Sat May 09, 2015 3:56 am
Is the arm securely on the shaft? Column shifter or floor shifter?
Sam
PostPosted: Sat May 09, 2015 4:54 am
it's not installed yet because of this issue. But ye s and will be a floor shifter
PostPosted: Sat May 09, 2015 7:48 am
Sounds like something is already broken inside the trans. Have you pulled the valve body yet?
PostPosted: Sat May 09, 2015 8:56 am
I was going to but family emergency came up I will asap
