It is currently Mon Nov 16, 2026 3:30 am
 Post subject: seperating 904 from /6
PostPosted: Sat Nov 29, 2014 10:43 pm
Car Model: 62 Valiant
if i have a slant and 904 as originally assembled (1970 a body) sitting in a crate on the floor, can i remove the starter, undo the bell housing bolts and inspection cover and slide them apart, or do i have to get inside and undo the flex plate bolts first?
PostPosted: Sat Nov 29, 2014 10:45 pm
It is best practices to remove the four flex platebolts first. However, if for some reason that isn't possible, the transmiusion can be removed once the bellhousing bolts are out but the torque converter will slide out of the front pump and will remoain attached to the flex plate.
PostPosted: Sun Nov 30, 2014 5:51 am
You can usually get the flex plate bolts through the starter hole. :D
