It is currently Sat Jun 20, 2026 4:22 am
PostPosted: Fri Dec 05, 2014 5:16 am
Just figured out photos so here's an annotated photo of my wiring. Do I have this right?
1. Relay post # 85 to 12v switched source at blue wire connector for ballast resistor.
2. Relay post # 30 to alternator output stud through 15A fuse.
3. Relay post # 87 to splice joining "B" terminal on module and coil + terminal.
4. "C" terminal on module to coil - terminal.
5/6. "W" and "G" terminals on module to distributor pick up pigtail.
7. Relay post # 85 to ground through fender with star washers and bolt/nut. Cleaned fender to bare metal both sides at contact.
Module is grounded with mounting screw through fender with star washers and lock nut. Cleaned under side to bare metal. Applied thermal grease between module and aluminum mounting plate.
Is this right?
1974 Dodge Dart, 225cid, A904, Factory A/C, "Special Edition"
 Post subject: Got her running!
PostPosted: Fri Dec 05, 2014 11:26 am
Apparently, the answe is yes. One thing to add though. You DO need a wire from the OEM coil + terminal and the HEI "B" terminal to your coil +. The original is necessary for the start/kill function of your ignition. Thanks to all!
PostPosted: Fri Dec 05, 2014 11:27 am
PostPosted: Mon Dec 08, 2014 4:44 pm
What a refreshing thread! A novel idea; members just answering their own questions! Twice! :lol: :lol: :lol:
Here are some more contributions to the chaos. Gm Hei Module Conversion Troubles
Olaf
Aspenized
PostPosted: Wed Dec 10, 2014 2:17 am
Lol. Sorry, didn't realize I double posted. :oops:
Users browsing this forum: Chris6064 and 1 guest
