It is currently Mon Nov 16, 2026 11:04 pm
 Post subject: crank register question
PostPosted: Tue Dec 30, 2014 6:03 pm
I know the crank registers changed from small to large in 67-68
my 68 Barracuda's block is stamped PT 225 T 2667
thinking I may have a 67 block
the auto flex plate bore ID measures: 2 5/32 or 2.15 inches
the torque converter stub measure 1 67/128 or 1.52 inches
the crank register measures 2.15 OD
some disparity between the crank - flex plate bore and the torque converter snout,,the mounting bolts line up..
*is this an issue,,
** do I have a large or small register ?
 Post subject: Isn't...
PostPosted: Tue Dec 30, 2014 6:18 pm
Your answer on page 2 of the first part of the slant sickness article?
PostPosted: Tue Dec 30, 2014 6:58 pm
This does not sound right to me. 2.15" crank hub OD sounds like big hub, but I know that the small hub has a 1.555" ID. Big hub crank ID is 1.815". Are you sure the converter you measured fits the crank hub without play?
All 1968 model year cars should have big hub and all 1967 should be small hub. Measuring is of course the iron clad test...
PostPosted: Tue Dec 30, 2014 7:12 pm
How many splines are on the 904's input shaft?
PostPosted: Tue Dec 30, 2014 8:01 pm
PT 225 T 2667
PT: Trenton engine plant
225: Cubic inch displacement
T: Truck engine
2667: Engine built on November 15, 1968
PostPosted: Wed Dec 31, 2014 11:19 am
thanks all for the replies,
must not be the original engine as the car was first titled in June of 68..
and 25 splines in the tranny end drive shaft connector
based upon the slant sickness article
lg 2.160 od and 1.850 id
sm 1.960 od and 1.530 id
just re checked and the crank od is 2.158
so it must be a large register crank,, makes sense with an engine build date in late 68,
however the torque converter snout measures 1.52xx
must be a large register crank combo'd with a small register torque converter,,
doesn't someone make an adapter to match up these registers?
thanks
PostPosted: Wed Dec 31, 2014 11:31 am
John, I have those crank adapters available, as does Doug, and TF Patty.
