| crank register question https://slantsix.org/forum/viewtopic.php?t=56827 |
| Author: | DadTruck [ Tue Dec 30, 2014 6:03 pm ] |
| Post subject: | crank register question |
I know the crank registers changed from small to large in 67-68 my 68 Barracuda's block is stamped PT 225 T 2667 thinking I may have a 67 block the auto flex plate bore ID measures: 2 5/32 or 2.15 inches the torque converter stub measure 1 67/128 or 1.52 inches the crank register measures 2.15 OD some disparity between the crank - flex plate bore and the torque converter snout,,the mounting bolts line up.. *is this an issue,, ** do I have a large or small register ? |
| Author: | DusterIdiot [ Tue Dec 30, 2014 6:18 pm ] |
| Post subject: | Isn't... |
Your answer on page 2 of the first part of the slant sickness article? |
| Author: | Dart270 [ Tue Dec 30, 2014 6:58 pm ] |
This does not sound right to me. 2.15" crank hub OD sounds like big hub, but I know that the small hub has a 1.555" ID. Big hub crank ID is 1.815". Are you sure the converter you measured fits the crank hub without play? All 1968 model year cars should have big hub and all 1967 should be small hub. Measuring is of course the iron clad test... Lou |
| Author: | Doctor Dodge [ Tue Dec 30, 2014 7:12 pm ] |
How many splines are on the 904's input shaft? DD |
| Author: | SlantSixDan [ Tue Dec 30, 2014 8:01 pm ] |
| Post subject: | Re: crank register question |
Quote: PT 225 T 2667
PT: Trenton engine plant225: Cubic inch displacement T: Truck engine 2667: Engine built on November 15, 1968 |
| Author: | DadTruck [ Wed Dec 31, 2014 11:19 am ] |
thanks all for the replies, must not be the original engine as the car was first titled in June of 68.. and 25 splines in the tranny end drive shaft connector based upon the slant sickness article lg 2.160 od and 1.850 id sm 1.960 od and 1.530 id just re checked and the crank od is 2.158 so it must be a large register crank,, makes sense with an engine build date in late 68, however the torque converter snout measures 1.52xx must be a large register crank combo'd with a small register torque converter,, doesn't someone make an adapter to match up these registers? thanks |
| Author: | Charrlie_S [ Wed Dec 31, 2014 11:31 am ] |
John, I have those crank adapters available, as does Doug, and TF Patty. |
