It is currently Sun Jun 07, 2026 12:11 pm
PostPosted: Mon Feb 02, 2015 10:25 pm
I have a 225 slant six, all stock and original in a 74 dart sport and I was wondering how do I find out if it uses a hydrolic cam or a mechanical cam?
PostPosted: Mon Feb 02, 2015 10:36 pm
Hydraulic didn't start until later, 78ish. So if your 74 setup is untouched then its mechanical. Another easy way to tell - open up the oil fill cap on the valve cover. Look at the rocker arm end opposite the valve. If there's an adjustment screw there it's mechanical, if there isn't its hydraulic.
PostPosted: Mon Feb 02, 2015 11:01 pm
Hydraulic started in '81. Hydraulic heads have a dogleg in the valve cover by the alternator.
PostPosted: Tue Feb 03, 2015 12:53 am
3 years counts within the realm of an -ish, right?
PostPosted: Tue Feb 03, 2015 1:22 am
Awesome thanks guys :)
PostPosted: Tue Feb 03, 2015 10:10 am
There was a production test run of hydraulic slant-6s in '78. Then the full-scale switchover happened for '81.
PostPosted: Tue Feb 03, 2015 8:45 pm
if you have a mid 70's slant cam,, you have one of these
G. Camshaft
The best production cam available for the slant six engines was used in the 1971-1977 engines. This cam (PN 3512639) has a 244 degree duration, 26 degree overlap and a lift of .406" on the intake and .414" on the exhaust. The valve lash of this cam should be .010" on the intake and .020" on the exhaust. Both of these settings are hot.
you can certainly get a bigger cam,,not a bad small cam the way it is,, some folks like em for turbo use.
