It is currently Wed May 13, 2026 4:35 am
 Post subject: part numbers
PostPosted: Wed Feb 04, 2015 2:13 pm
Can anyone help me out with Mopar or Hollanders numbers for a flywheel and bell housing for /6 to np435? I haven't had any luck getting a set that goes togetherbut if I had the correct numbers that should help.
Thanks in advance
Dave
1972 d-100 parts truck
 Post subject: Hollanders
PostPosted: Wed Feb 04, 2015 7:13 pm
Numbers are:
Bellhousing
66-68 #655
69-79 #661
Flywheel
65-68 #365
69-79 #496
Which are not entirely correct since there is a flywheel step off in "teeth" in the 70's, but the high tooth count early flywheel was used on industrual engines into the early 70's at least....Bellhousing changed in style with the flywheel change/tooth count.
And this ad:
http://portland.craigslist.org/clk/pts/4865163859.html
Which is the nice late bell and flywheel from the mid-70's on...
and maybe:
http://eugene.craigslist.org/pts/4822111605.html
Which would be the early version with the 9 tooth starter, and the hydraulic clutch slave cylinder and bracketry on the passenger side of the bellhousing....
PostPosted: Thu Feb 05, 2015 9:26 pm
Thanks for the lead.
Dave
 Post subject: Another one
PostPosted: Fri Feb 06, 2015 5:54 am
You know this guy is just to the north of me a bit:
http://portland.craigslist.org/clc/pts/4878022765.html
