| part numbers https://slantsix.org/forum/viewtopic.php?t=57045 |
| Author: | nuttyprof [ Wed Feb 04, 2015 2:13 pm ] |
| Post subject: | part numbers |
Can anyone help me out with Mopar or Hollanders numbers for a flywheel and bell housing for /6 to np435? I haven't had any luck getting a set that goes togetherbut if I had the correct numbers that should help. Thanks in advance |
| Author: | DusterIdiot [ Wed Feb 04, 2015 7:13 pm ] |
| Post subject: | Hollanders |
Numbers are: Bellhousing 66-68 #655 69-79 #661 Flywheel 65-68 #365 69-79 #496 Which are not entirely correct since there is a flywheel step off in "teeth" in the 70's, but the high tooth count early flywheel was used on industrual engines into the early 70's at least....Bellhousing changed in style with the flywheel change/tooth count. And this ad: http://portland.craigslist.org/clk/pts/4865163859.html Which is the nice late bell and flywheel from the mid-70's on... and maybe: http://eugene.craigslist.org/pts/4822111605.html Which would be the early version with the 9 tooth starter, and the hydraulic clutch slave cylinder and bracketry on the passenger side of the bellhousing.... |
| Author: | nuttyprof [ Thu Feb 05, 2015 9:26 pm ] |
Thanks for the lead. |
| Author: | DusterIdiot [ Fri Feb 06, 2015 5:54 am ] |
| Post subject: | Another one |
You know this guy is just to the north of me a bit: http://portland.craigslist.org/clc/pts/4878022765.html |
