It is currently Sun May 31, 2026 11:01 pm
PostPosted: Thu Feb 12, 2015 4:43 am
Just converted my 65 Dart Throttle Rod Linkage to 67 and up Cable Throttle Linkage system.
It's functioning fine however I'm wondering if a clip is suppose to be used where the cable goes through the firewall into the bracket arrangement where the inner cable drops into the swinging arm. I have a rubber plug that retains the cable ball in the swing arm.
There are two grooves in the cable outside body that suggest a clip might go to hold the cable at the firewall.
 Post subject: Yep...
PostPosted: Thu Feb 12, 2015 5:04 am
Yes, if your have the 67-74 cable it has a circular clip that fits the grooves and retains the plug to the wall...75+ with the square plug uses a strip of metal through the plug to retain it.
 Post subject: Used E-Ring For Retainer
PostPosted: Mon Feb 16, 2015 10:59 am
Thank you for the prompt response.
I found a 5/16 E-Ring which seemed to work as a retainer for the cable.
First, from under the hood, I held the cable in a position with cable so that it was perpendicular to the firewall and pulled up against the firewall/accelerator bracket.
Using needle nose pliers I was able to work the E-Ring into the outer slot from under the dash.
DI-Thank You for your help
Don
 Post subject: Also...
PostPosted: Mon Feb 16, 2015 4:46 pm
If it doesn't hold I think you can also look at 90's minivans and 80's K-cars for a similar clip that might work also.
:wink:
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
