It is currently Fri May 22, 2026 11:09 am
PostPosted: Sat Mar 14, 2015 2:41 pm
I have searched but haven't seen a clear answer regarding the crank snout seal in the timing cover for my 225. Looking at it from the inside I believe the seal should be installed with the metal spring that circles the rubber facing in toward the engine and the metal shoulder facing out the front. Is that correct?
Would you suggest some type of sealer around the outside edge before pressing it in?
Getting a little paranoid about every little detail and questioning my self.
Thanks for the help,
Metal Turkey
PostPosted: Sat Mar 14, 2015 5:51 pm
Yes that is the right direction. I use a bit of #2 Permatex around them. Take your time and tap/press it in a bit at a time to keep it straight and round.
 Post subject: sealant
PostPosted: Sat Mar 14, 2015 11:04 pm
FYI, I didn't use any sealant last time and it didn't leak at all.
I went to my local hardware store and found a green PVC drain cover pipe end that fit perfectly into the seal and touched only the metal. I sanded the end perfectly flat and I used it to tap the seal into place, works perfectly. I keep in my tool drawer marked "special" tools.
https://tinyurl.com/yynpj4v2
 Post subject: hmmm....
PostPosted: Sat Mar 14, 2015 11:06 pm
Now that I'm thinking about it, I bet one of the rings in my ball joint installer might fit, I'll check and let you know.
PostPosted: Sun Mar 15, 2015 6:54 am
Thanks for the information, I know it looks fairly obvious but the closer I get to finishing this project the more cautious I have become.
Those are some awesome pictures lots of great detail shots. I have just a tad bit more room to work on the engine in my stock D100. However it may not go as fast as your Dart.
Heading to the Good Guys Car show here in Phoenix this morning.
Thanks,
Metal Turkey
 Post subject: no problem...
PostPosted: Sun Mar 15, 2015 10:25 am
The folks here are happy to help, and as to sweating the details, I've asked the same question and tend to forget small things and have to ask again.
b
 Post subject: results...
PostPosted: Sun Mar 15, 2015 11:51 am
I didn't find a ring in my ball joint press kit that was the same size as the PVC thingy.
I find that pictures help, so here are some pics of my timing cover seal installer (cost $2).
Top view showing the brand, I got it at OSH: http://s785.photobucket.com/user/67dart ... sort=3&o=4
I sanded the bottom part flat, it was a bit uneven new: http://s785.photobucket.com/user/67dart ... sort=3&o=3
It fits perfectly between the seal and the outer body, rests perfectly flat onto the bottom surface of the seal casing:
http://s785.photobucket.com/user/67dart ... sort=3&o=2
http://s785.photobucket.com/user/67dart ... sort=3&o=1
As you can see there is no sign of damage whatsoever to the seal case after tapping it in (this is my old seal, I'm going to replace it the same way). http://s785.photobucket.com/user/67dart ... sort=3&o=0
This tool has a nice top surface to put a small chunk of 2x4 across so you evenly distribute the force. I might use a little sealant this time as it may help it slide in even easier, can't hurt.
Brian
PostPosted: Sun Mar 15, 2015 2:08 pm
Like 270 said-
"Special tools" for re-bushing the front suspensions on our Darts: our local (McLendon's) hardware store has a really good plumbing dept. So all my "special tools" are made of strong plastic, brass pipe, copper, steel, pipe caps & plugs, etc. Front wheel bearing seal driver: a plastic pipe cap. Nothing like a good builders' supply for special tools. :)
PostPosted: Sun Mar 15, 2015 4:10 pm
Thanks for the pictures of your specialty tool, I think I will stop by Ace hardware and see if I can pick up the same plumbing drain cover. I need all the special tools I can find.
Plan to start the NP435 rebuild this week, that should be interesting as I have never done one before. Oh well, like they say "if you can't run with the big dogs stay on the porch".
Thanks,
Metal Turkey
 Post subject: sanding the end...
PostPosted: Sun Mar 15, 2015 5:29 pm
I just lay a piece of sandpaper on a really flat surface and orbit the piece on top of the sandpaper, one hand to hold the sandpaper still the other orbits the work piece around. I don't have a turntable sander...
brian
PostPosted: Mon Mar 16, 2015 7:06 am
Thanks, those are the kind of instructions even I can't screw up.
Metal Turkey
PostPosted: Mon Mar 16, 2015 6:24 pm
Got my new green drain tool, used it and it worked great.
Thanks for the advice,
Metal Turkey
Users browsing this forum: Bing [Bot] and 9 guests
