It is currently Sat Jun 13, 2026 12:42 pm
PostPosted: Tue Feb 24, 2015 11:13 am
As I have discussed previously, I have been fighting motor mounts for a couple of weeks. Well, I am glad to report that I got those puppies in there finally. Now I have another problem. In the process of putting it all back together I decided for to go ahead and install a new fuel pump,filter, line. When I went to start it, fuel just started pouring out of the side of the carb at the economizer diaphragm. So, what do I have?
1. A fuel pump that is putting out too much pressure. Is the diaphragm a weak point where excess pressure is allowed to escape?
2. Or, do you think that the pump pressure is fine? The carb just needs a rebuild. The new pressure just exposed a weak link? Faulty diaphragm?
3. Something else entirely?
Thanks for your input!
PostPosted: Tue Feb 24, 2015 11:38 am
Faulty/misadjusted float and/or needle and seat in the carb.
 Post subject: rebuild
PostPosted: Tue Feb 24, 2015 12:02 pm
Should I just plan on a rebuild? Aren't floats hard to find for this model?
 Post subject: Re: rebuild
PostPosted: Tue Feb 24, 2015 12:24 pm
It wouldn't hurt anything if it is done right.
I don't know. What kind of carb do you have?
 Post subject: carb
PostPosted: Tue Feb 24, 2015 12:26 pm
The Holley 1920.
PostPosted: Tue Feb 24, 2015 12:34 pm
$12.42 on eBay including shipping.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
