| The saga continues, now carb problems! https://slantsix.org/forum/viewtopic.php?t=57156 |
| Author: | GAranger1403 [ Tue Feb 24, 2015 11:13 am ] |
| Post subject: | The saga continues, now carb problems! |
As I have discussed previously, I have been fighting motor mounts for a couple of weeks. Well, I am glad to report that I got those puppies in there finally. Now I have another problem. In the process of putting it all back together I decided for to go ahead and install a new fuel pump,filter, line. When I went to start it, fuel just started pouring out of the side of the carb at the economizer diaphragm. So, what do I have? 1. A fuel pump that is putting out too much pressure. Is the diaphragm a weak point where excess pressure is allowed to escape? 2. Or, do you think that the pump pressure is fine? The carb just needs a rebuild. The new pressure just exposed a weak link? Faulty diaphragm? 3. Something else entirely? Thanks for your input! |
| Author: | Reed [ Tue Feb 24, 2015 11:38 am ] |
Faulty/misadjusted float and/or needle and seat in the carb. |
| Author: | GAranger1403 [ Tue Feb 24, 2015 12:02 pm ] |
| Post subject: | rebuild |
Should I just plan on a rebuild? Aren't floats hard to find for this model? |
| Author: | Reed [ Tue Feb 24, 2015 12:24 pm ] |
| Post subject: | Re: rebuild |
Quote: Should I just plan on a rebuild?
It wouldn't hurt anything if it is done right.Quote: Aren't floats hard to find for this model?
I don't know. What kind of carb do you have?
| Author: | GAranger1403 [ Tue Feb 24, 2015 12:26 pm ] |
| Post subject: | carb |
The Holley 1920. |
| Author: | Reed [ Tue Feb 24, 2015 12:34 pm ] |
$12.42 on eBay including shipping. |
