It is currently Thu Jun 11, 2026 4:38 pm
PostPosted: Sat Feb 28, 2015 2:39 pm
H'mmm…now here's an oddball valve cover I've not seen before. Looks like a '70-up stamping, but with one front chimney (per '60-'69) and one rear hole (small for PCV valve grommet per '66-'69, not large for breather grommet per '70-up). The boss for the '70-up central PCV valve location is present, but there's no hole. I'm guessing it's a service replacement item supplied in later years by Chrysler for older applications.
PostPosted: Sat Feb 28, 2015 2:51 pm
I'm pretty sure it's for the alloy head models :lol:
PostPosted: Sat Feb 28, 2015 3:01 pm
I doubt there is a part number ?
Could it be for a marine application or industrial application that had possibly less stringent Emissions?
PostPosted: Sat Feb 28, 2015 3:20 pm
'70-up industrial/marine enignes I've seen have all had the '70-up 3-hole valve cover.
No part number.
Aluminum head model: you might be on to something there! Image
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
