It is currently Sun Nov 29, 2026 11:53 am
 Post subject: quick survey
PostPosted: Sat Feb 28, 2015 7:44 pm
Does anyone use polyurethane LCA bushings?
IF so, happy, no squeaks?
If not, because they squeaked?
I was thinking of getting the ones with the channels cut in the inner hole where the pins go, and use the pins with zerk fittings to grease those baby's.
I've heard all kinds of stories, bad and good, about poly LCA bushings. Some say no squeaks no issues, other's say OMG I'm ready to blow my head off to escape the squeaking...could it be they just aren't lubricating them correctly? Everyone seems to say that poly is better than rubber.
thanks,
Brian
https://tinyurl.com/yynpj4v2
 Post subject: Ok
PostPosted: Sun Mar 01, 2015 6:31 pm
I did some reading on these posts, I'm going with rubber all the way....
brian
