It is currently Fri Aug 28, 2026 8:27 pm
PostPosted: Tue Mar 03, 2015 12:00 pm
I am planning ahead to when I get to start the bodywork on my brother's Duster. We are using a pair of 1968 Dart fenders from a real 68 Dart GTS. The problem is that the fenders have factory tape stripes on them.
Can anyone suggest a good method for removing the factory tape stripes?
Thanks!
PostPosted: Tue Mar 03, 2015 12:03 pm
Heat gun will soften them up. Propane torch will work too, just don't stay in one spot too long.
PostPosted: Tue Mar 03, 2015 12:40 pm
Thanks!
What about those 3M decal remover wheels? The fenders are going to be repainted after the stripes are removed.
PostPosted: Tue Mar 03, 2015 2:53 pm
I've had good luck with those, but the last time I used one it was to remove factory stripes that were about seven years old. Can't say if (much) older stripes will be easier or harder; give it a try.
PostPosted: Tue Mar 03, 2015 3:57 pm
Thanks! I'll give them a go. As much fun as it is to play with fire, it isn't my tool of first resort.
