It is currently Sun Nov 29, 2026 7:21 am
PostPosted: Fri Mar 06, 2015 6:07 pm
I have some aftermarket tie rods, they have a lock nut, not the bolt like the factory ones.
I figure I'll use locktite on them for safety, but is the blue stuff sufficient? I try not to use the red unless I really have to 'cause it's either hard to get off or you have to heat the part and I don't like to heat aluminum if I can help it.
thanks,
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri Mar 06, 2015 11:11 pm
I wouldn't bother. Torque it to spec and be done. The shaft is a taper fit, any nut already is a safety.
 Post subject: Thanks...
PostPosted: Sat Mar 07, 2015 9:01 am
I think an easy compromise is to use the green penetrating one. Torque to spec like you suggest, then just a drop of green for peace of mind.
PostPosted: Sun Mar 08, 2015 5:41 am
It's not needed, but use the blue if you want too; no need for the red at all. I've never seen/had a properly torqued tie rod nut come loose, even in severe racing conditions (rallying).
