| a different tie rod end question https://slantsix.org/forum/viewtopic.php?t=57227 |
| Author: | '67 Dart 270 [ Fri Mar 06, 2015 6:07 pm ] |
| Post subject: | a different tie rod end question |
I have some aftermarket tie rods, they have a lock nut, not the bolt like the factory ones. I figure I'll use locktite on them for safety, but is the blue stuff sufficient? I try not to use the red unless I really have to 'cause it's either hard to get off or you have to heat the part and I don't like to heat aluminum if I can help it. thanks, Brian |
| Author: | Pierre [ Fri Mar 06, 2015 11:11 pm ] |
I wouldn't bother. Torque it to spec and be done. The shaft is a taper fit, any nut already is a safety. |
| Author: | '67 Dart 270 [ Sat Mar 07, 2015 9:01 am ] |
| Post subject: | Thanks... |
I think an easy compromise is to use the green penetrating one. Torque to spec like you suggest, then just a drop of green for peace of mind. |
| Author: | nm9stheham [ Sun Mar 08, 2015 5:41 am ] |
It's not needed, but use the blue if you want too; no need for the red at all. I've never seen/had a properly torqued tie rod nut come loose, even in severe racing conditions (rallying). |
