It is currently Mon Nov 23, 2026 12:12 am
PostPosted: Sun Mar 08, 2015 6:54 pm
If I get asked why not a v8 or wouldn't a 350 be easier again ill freak
PostPosted: Sun Mar 08, 2015 7:11 pm
PostPosted: Sun Mar 08, 2015 7:24 pm
<img src="http://i1301.photobucket.com/albums/ag107/johnhobbick/20150308_182446_zps754c2f2b.jpg" border="0" alt=" photo 20150308_182446_zps754c2f2b.jpg"/>
PostPosted: Sun Mar 08, 2015 7:25 pm
that looks like fun.
PostPosted: Mon Mar 09, 2015 5:40 am
Super cool. Can't wait to see/hear/learn about it running! What boost level target? Would love to hear more about the details of the whole setup - turbo size/type, pics of intake...
PostPosted: Mon Mar 09, 2015 6:30 am
Exciting setup! At what level of boost will you have a transition from blower to turbo as main source? Do you have to use some blowback preventing baffles or valves?
Olaf
Aspenized
PostPosted: Mon Mar 09, 2015 7:24 am
I'm using the stock bypass valve with a hobbs switch to bypass the supercharger once the turbo spools up and it's all up in the air right now but I think I will switch over to turbo around 13 ish psi but the blower according to my math will make around 11 psi not considering any lose do to rotary wear ect.
PostPosted: Mon Mar 09, 2015 5:19 pm
(picture of turbo and supercharged slant 6)
You win.
PostPosted: Mon Mar 09, 2015 8:28 pm
Next time I get out there I'll take pics of the intake but it's an eaton m90 with the ports smoothed out and a lot of the unused ports like the pcv filled in. I'm running it with ms2 using map/ batch fire. The turbo is a holset wh1c running through the stock housing with the waste gate welded shut ( using an external waste gate) the exhaust manifold is wrapped, all the pulleys I made at work.using 80lbs injectors for e85 hoping to run upwards of 15 psi and if I can get away with it I might try run more with me meth injection . Epoxies the advance mechanism it the distributor and will be using MS2 for my ignition curve ......if I haven't thought of anything please remind me because I want some input or suggestions
 Post subject: ,.
PostPosted: Sat Mar 14, 2015 4:02 pm
I wouldn't use locked out timing due to distributor rotor phasing issues. Instead, I'd run a conservative mechanical curve and use your computer to add a few degrees when needed
PostPosted: Tue Jun 30, 2015 2:17 pm
Pretty sweet setup probably going to lift the head tho better get some bigger head studs
