It is currently Mon Oct 26, 2026 9:25 am
PostPosted: Thu Mar 19, 2015 9:59 am
Hi
I have 225 that I just did a 4bbl manifold swap on, and I looking for any advice about how to get the kick down lever system in place...for some reason it doesn't seem to want to fit into place anywhere I need it to and the instructions are as clear as mud
Thanks,
LG73
PostPosted: Thu Mar 19, 2015 1:21 pm
You will need to fabricate something. Nothing is going to bolt on. I like the Gearhead cable kick down for $30. You still need to make up a bracket for up top to hold the cable in the right place. Here is what I did to my truck.
http://slantsix.org/forum/viewtopic.php ... 7&start=45
Rick
PostPosted: Thu Mar 19, 2015 3:39 pm
I have a Lokar lockdown cable on my Offy manifold. It was a little more expensive than the setup Rick has, but like he said, you will need to fab up something.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Mar 19, 2015 10:23 pm
I figured as much, it was just what it needed to look like was the issue. The instructions mention some type of L-bracket but I think I can make one like Rick's that'll work
