It is currently Thu Jul 09, 2026 4:20 pm
 Post subject: Two Post Mirror
PostPosted: Fri Apr 03, 2015 3:05 pm
How do I fix a sloppy mirror head?
Thanks
PostPosted: Sun Apr 05, 2015 9:01 am
If your mirrior has a snap ring that holds the glass in(some do, some don't) you can remove the glass and you will find a screw that just needs tightened. If the glass is not removable, set your mirror and drip super glue into the ball and socket.That was a fix from Mopar Action magazine.And if you have to adjust after the glue dries, you can as the hardened glue will tighten the ball and socket clearance.
Users browsing this forum: Ahrefs [Bot] and 1 guest
