It is currently Fri Jul 10, 2026 9:08 am
PostPosted: Mon Apr 06, 2015 8:12 am
I am looking for door hinge bushing and pin for my 62 Lancer 4 door. Is there anything available?
Cheers,
B
These ones go to eleven...
PostPosted: Mon Apr 06, 2015 10:15 am
Not as an off-the-shelf item; you'll need to check with door hinge refurb specialists.
PostPosted: Mon Apr 06, 2015 5:15 pm
Thanks Dan!
PostPosted: Mon Apr 06, 2015 6:18 pm
If you get desperate you might be able to find something else that will work for the bushing. I worked at an independent VW shop for a while and needed to re-bush hinges on a karmengia (they don't have bushings originally) and found that a bronze valve guide insert worked perfectly. More than likely if you can find a real parts man you could look through bushings and pins for other cars and find one that will work.
Dave
1972 d-100 parts truck
PostPosted: Mon Apr 27, 2015 12:37 am
Use roll pins - they have a long slit in them.
A dab of weld at top of hinge to hold them in place.
They work better than the original door pin.
Users browsing this forum: Amazon [Bot] and 1 guest
