| 62 Lancer Door Hinge Bushing https://slantsix.org/forum/viewtopic.php?t=57455 |
| Author: | Lobster1 [ Mon Apr 06, 2015 8:12 am ] |
| Post subject: | 62 Lancer Door Hinge Bushing |
I am looking for door hinge bushing and pin for my 62 Lancer 4 door. Is there anything available? Cheers, B |
| Author: | SlantSixDan [ Mon Apr 06, 2015 10:15 am ] |
Not as an off-the-shelf item; you'll need to check with door hinge refurb specialists. |
| Author: | Lobster1 [ Mon Apr 06, 2015 5:15 pm ] |
Thanks Dan! |
| Author: | nuttyprof [ Mon Apr 06, 2015 6:18 pm ] |
If you get desperate you might be able to find something else that will work for the bushing. I worked at an independent VW shop for a while and needed to re-bush hinges on a karmengia (they don't have bushings originally) and found that a bronze valve guide insert worked perfectly. More than likely if you can find a real parts man you could look through bushings and pins for other cars and find one that will work. |
| Author: | crickhollow [ Mon Apr 27, 2015 12:37 am ] |
Use roll pins - they have a long slit in them. A dab of weld at top of hinge to hold them in place. They work better than the original door pin. |
