It is currently Tue Oct 13, 2026 10:28 pm
PostPosted: Sun Apr 12, 2015 1:23 pm
why do a lot of gofast cars do this? all answers welcome.
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Apr 12, 2015 7:42 pm
They use the extra room for headers on most of the v8 cars I've seen
Kev
PostPosted: Mon Apr 13, 2015 12:37 am
More room and a little weight savings, especially if the car is caged.
PostPosted: Mon Apr 13, 2015 6:11 am
Less weight on the front , ease of access to engine, suspension etc. More design freedom to mount / locate components etc.
PostPosted: Mon Apr 13, 2015 8:10 am
is this OK for street use? issues ?
slant six's RULE!
PostPosted: Mon Apr 13, 2015 11:54 am
That's a lot of structure to remove. It's not just along for the ride. Unless you plan on running a roll cage with tubes extended to the subframe in front of the suspension mounting points I would keep them. They also keep the engine compartment much cleaner.
PostPosted: Mon Apr 13, 2015 12:29 pm
Car Model: Toad Wagon
Yep, on "unibody" cars they're structural components. When removed, they need to be replaced with something performing the equivalent work.
Hell, even the bolt-on fenders add a small structural function to this style engineering.
Sex, drags, and rock & roll.
Dick, 225% crazy.
