It is currently Wed Oct 07, 2026 12:15 pm
PostPosted: Mon May 04, 2015 8:23 am
I'm in the process of trying to find a rebuildable engine for my D100. The scrap guy that comes to my shop said he has one in a D200 truck, he THINKS its a 68, now i need the large crank register to fit my tranny so if this motor has 5 freeze plugs is that a reliable way to quickly tell if it is a 68 up motor? if not how can i quickly tell?
Thanks
Kevin
crossthreads are better than locktite
PostPosted: Mon May 04, 2015 10:22 am
Five freeze plugs is a good indicator, as is the block casting number. You want a block with casting number 2806830. This is the number for 68-up 225 blocks.
PostPosted: Mon May 04, 2015 1:05 pm
2806830 is the number for the '68 to mid-'76 block. Starting in mid-'76, with the advent of the cast crank, the block number changed. It changed again several times after that, too.
PostPosted: Mon May 04, 2015 1:55 pm
Look here for various casting numbers.
PostPosted: Mon May 04, 2015 6:09 pm
Thanks guys I appreciate the tips :-)
