It is currently Sun Nov 15, 2026 12:35 pm
 Post subject: 904 issue
PostPosted: Tue May 05, 2015 3:31 pm
Ran into a rather strange issue. don’t know how serious it is but it looks to be where the kick down connects. Moved it out today to prep for install. And the piece went down inside, I can see it but how to get it out?
http://s280.photobucket.com/user/Camiki ... sort=1&o=0
http://s280.photobucket.com/user/Camiki ... sort=1&o=2
http://s280.photobucket.com/user/Camiki ... sort=1&o=3
PostPosted: Tue May 05, 2015 4:45 pm
If the line pressure rod falls into the case you have a problem. At the very least you need to pull the valve body and see if it is damaged.
