Removal of inner speedo cable
https://slantsix.org/forum/viewtopic.php?t=57679
Author:  crickhollow [ Tue May 12, 2015 11:24 pm ]
Post subject:  Removal of inner speedo cable
How do I remove the inner speedo cable?
I have a 62 Valiant/Signet and have the cable disconnected at both cluster and traany. I have not been able to pull the inner cable from the cluster end or the tranny end.
Author:  Louise76 [ Wed May 13, 2015 9:56 pm ]
If it was working, then I think it should come out the top. If it wasn't working, my guess is it is fubar- as in unravelled inside the outer housing.
Author:  crickhollow [ Sun May 17, 2015 3:51 am ]
I got it out from the top after using some heavy elbow grease.
I think the inner cable was held in by lubricant that had dried hard over the years of non-use. I have cleaned the inner cable and it looks ok to use again.
Any idea on how I could clean the inside of the outer speedo cable of the congealed grease/lubricant?
Thanks
Author:  NEVjr [ Sun May 24, 2015 10:02 pm ]
Thanks
i would try flushing it with a varsol bath, but make sure varsol wont harm it first
