It is currently Wed Jun 17, 2026 2:24 pm
 Post subject: compression ratio
PostPosted: Tue May 26, 2015 6:40 am
Can someone tell me if my compression ratio of 8.5:1 is good or not for a SL6
PostPosted: Tue May 26, 2015 7:38 am
That's pretty good if it's a stock or other short duration cam. Most engines don't even have 8:1 stock. I tore one down that measure out to be 7.6:1.
PostPosted: Tue May 26, 2015 4:47 pm
If it actually measures out at 8.5:1 that's pretty good.
 Post subject: x3
PostPosted: Tue May 26, 2015 5:20 pm
Exactly... the 60's engines I've torn down are in the high-7 to very low 8 range, and the 70's engines being a little better to stay above 8....
 Post subject: Re: compression ratio
PostPosted: Wed May 27, 2015 6:15 pm
Are you measuring something somehow and thinking it is compression ratio? Like using a compression gauge?
It may be marked in both psi and 'atmospheres' of pressure. 8.5 atmospheres is around 120-125 psi which is pretty decent, if on all cylinders. Is this what you are really asking?
PostPosted: Wed May 27, 2015 7:56 pm
i was told that the compression ratio was 8.5ish:1 by its previous owner so i was asking to see if it was good
PostPosted: Thu May 28, 2015 1:12 pm
Not sure what the PO was trying to tell you. The compression ratio is only measured and calculated with the engine apart. I don't know of any common or convenient way to measure it in-car and it is not a field service measurement. It is a general specification of an engine, not something you measure to see if there is a problem or not.
Measurements made 'in the field' are cylinder compression (good is in the 120 +/- psi range stock for this engine, stock), and compression leak down, which measures the % of air leakage from a pressurized cylinder; that is measured in %.
So the number the PO gave you is meaningless as to the engine's condition.; it is just a book factory spec, or the PO built the engine to that 8.5:1 spec (and hopefully checked it in the build). Is this a stock engine?
PostPosted: Thu May 28, 2015 3:17 pm
For a completely stock Slant 8.5 would be very good. Without measuring everything it is just a number somebody pulled out of their posterior.
PostPosted: Tue Jun 02, 2015 8:27 am
I believe mine is 6.8:1? Gotta look it up again. My block had insane amount of deck
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 7 guests
