It is currently Sun Nov 22, 2026 1:22 am
 Post subject: slant 6 crankshaft
PostPosted: Sat May 17, 2003 6:32 am
Hi all, new to the board :)
Can anyone enlighten me on the slant 6 crankshaft. I need to do an engine swap in my truck (1982 Dodge 4x4 4 speed) The engine is out of a station wagon with an automatic trans. If my memory is correct the manual transmissions use a pilot bushing in the crank.
Will the crank in the engine with the auto tranny be drilled for the pilot bushing??
Thanks,
Mark K
PostPosted: Sat May 17, 2003 12:40 pm
If it's not, you can go to Dodge and get the roller bearing for a Dakota truck. It's about $10. :shock:
One thing to check is that the motor you want to put in is a '68 and newer. The '67 and older had a smaller register on the back of the crank. :shock:
PostPosted: Sat May 17, 2003 4:29 pm
Thanks for the info. The engine is out of a 79 Volarie wagon.
Thanks again,
Mark K
