| slant 6 crankshaft https://slantsix.org/forum/viewtopic.php?t=5776 |
| Author: | snowcomander6 [ Sat May 17, 2003 6:32 am ] |
| Post subject: | slant 6 crankshaft |
Hi all, new to the board Can anyone enlighten me on the slant 6 crankshaft. I need to do an engine swap in my truck (1982 Dodge 4x4 4 speed) The engine is out of a station wagon with an automatic trans. If my memory is correct the manual transmissions use a pilot bushing in the crank. Will the crank in the engine with the auto tranny be drilled for the pilot bushing?? Thanks, Mark K |
| Author: | slantzilla [ Sat May 17, 2003 12:40 pm ] |
If it's not, you can go to Dodge and get the roller bearing for a Dakota truck. It's about $10. One thing to check is that the motor you want to put in is a '68 and newer. The '67 and older had a smaller register on the back of the crank. |
| Author: | snowcomander6 [ Sat May 17, 2003 4:29 pm ] |
Thanks for the info. The engine is out of a 79 Volarie wagon. Thanks again, Mark K |
