It is currently Mon Nov 16, 2026 11:47 am
 Post subject: Kickdown linkage
PostPosted: Fri Jun 12, 2015 4:32 pm
Anybody know how to set the kickdown and where to get the linkage
PostPosted: Sat Jun 13, 2015 9:18 am
1 or 2bbl carb?
What year / model vehicle?
PostPosted: Sat Jun 13, 2015 10:14 am
4bbl 80 d150 904
PostPosted: Sat Jun 13, 2015 10:44 am
Lokar. Set it so the arm on the trans is all the way back at wide open throttle.
 Post subject: another add on
PostPosted: Mon Jun 15, 2015 9:12 am
what's the 904 fluid capacity
PostPosted: Mon Jun 15, 2015 9:53 am
Sounds like a question for a factory service many. My fuzzy recollection is that it is somewhere around 15-18 pints if you are filing the torque converter as well as the trans pan. Get 8 quarts of ATF (use the right kind) and fill it until it shows full while hot and idling. You may need slightly more or less than 8 quarts.
Users browsing this forum: Ahrefs [Bot] and 3 guests
