| Kickdown linkage https://slantsix.org/forum/viewtopic.php?t=57874 |
| Author: | camiking23 [ Fri Jun 12, 2015 4:32 pm ] |
| Post subject: | Kickdown linkage |
Anybody know how to set the kickdown and where to get the linkage |
| Author: | Doctor Dodge [ Sat Jun 13, 2015 9:18 am ] |
1 or 2bbl carb? What year / model vehicle? |
| Author: | camiking23 [ Sat Jun 13, 2015 10:14 am ] |
4bbl 80 d150 904 |
| Author: | Reed [ Sat Jun 13, 2015 10:44 am ] |
Lokar. Set it so the arm on the trans is all the way back at wide open throttle. |
| Author: | camiking23 [ Mon Jun 15, 2015 9:12 am ] |
| Post subject: | another add on |
what's the 904 fluid capacity |
| Author: | Reed [ Mon Jun 15, 2015 9:53 am ] |
Sounds like a question for a factory service many. My fuzzy recollection is that it is somewhere around 15-18 pints if you are filing the torque converter as well as the trans pan. Get 8 quarts of ATF (use the right kind) and fill it until it shows full while hot and idling. You may need slightly more or less than 8 quarts. |
