It is currently Thu May 21, 2026 3:57 am
PostPosted: Fri Jul 10, 2015 2:19 pm
Car Model: 1984 dodge D150 slant6 single cab long be step-sid
I purchased and rebuild motor. I have a 1984 dodge d150 single cab long bed step side \6 225 3.7L single barrel carb 2wd..
I'm trying to find out some things about turning this into a 4wd and putting leafs in the front. I'm not concerned just yet about the actual transfer case and being able to use 4wd yet I just want to have the independent axle and change my suspension.. I need all new front suspension parts as it is so I was wondering how hard or easy it would be to co very this and about what it would cost... The biggest thing is idk what front axle assembly will fit on it ... I want to get just the whole assembly and I would buy a lift kit so not worried about leafs. What years fits my truck? I want the lug pattern to match my rear axle...trying to avoid having to change the rear because it is in good shape.
Any help would be appreciated. Cost is a factor of course thanks in advance let me know if you need more info thanks!😁
PostPosted: Fri Jul 10, 2015 2:44 pm
All your questions have ben discussed at length on www.ramchargercentral.com
Search around on that site.
