It is currently Fri Nov 20, 2026 10:00 pm
 Post subject: Valve adjustment revisit
PostPosted: Thu Jul 16, 2015 7:30 pm
I have read Dan's fabulous post from years ago on valve adjustment.
I just have one question. I had the head rebuilt. do I need to do anything before starting the car the first time? Do I need to preset or just start it let it warm up and then pop the cover and get to it.
I had exhaust guides, all seats done, head surfaced, all valves ground and springs shims.
hot rodder at heart!
PostPosted: Thu Jul 16, 2015 7:42 pm
Yes, adjust them not running cold, but add maybe 0.002-3, so 12 and 22 thousandths for a stock cam to accommodate for expansion (and the shrinking gap) when warm.
PostPosted: Thu Jul 16, 2015 7:47 pm
I always adjust cold before starting. It saves bending pushrods and lighting the aircleaner on fire.
......and...after I start it; I warm it up ....shut it off and adjust them again warm.
There is another method involving adjusting while running.....messy,,,, inaccurate.....yet factory approved.
 Post subject: valve adjust
PostPosted: Fri Jul 17, 2015 8:54 am
Yes, absolutely adjust them during assembly so you don't bend pushrods or whatnot....and yes, leave a few thousandths extra to account for expansion, but after break in, set hot while running as the manufacturer intended.
It doesn't have to be messy. I use some masking tape and four kitchen garbage bags to make a heart surgery type "sterile field." It catches all the oil, and when done simply wrap it all up in a ball and dispose of - no mess!
See: http://tinyurl.com/sterile-field
I'm still figuring out exactly the right feel of the gap tool, but that's why they call them "feeler gauges" I suppose. Also, I used heater hoses with 90 degree bends and a few "S" hoses so I can remove my valve cover easily for this adjustment.
See: http://s785.photobucket.com/user/67dart ... ort=3&o=12
http://s785.photobucket.com/user/67dart ... ort=3&o=13
http://s785.photobucket.com/user/67dart ... ort=3&o=14
http://s785.photobucket.com/user/67dart ... ort=3&o=17
Brian
https://tinyurl.com/yynpj4v2
 Post subject: ...another tip
PostPosted: Fri Jul 17, 2015 8:59 am
I take a black sharpie and label the masking tape along the side closest to the manifolds with: E I E I E I I E I E I E so I have a quick reminder of which rocker I'm adjusting
 Post subject: Sterile field
PostPosted: Fri Jul 17, 2015 9:20 am
The Doctor is in! :lol:
 Post subject: one more question
PostPosted: Fri Jul 17, 2015 9:25 am
Is there a problem using one of those homemade tools (the hollow spark plug and bolt) to find top dead center or should I use a different method?
PostPosted: Fri Jul 17, 2015 1:17 pm
nothing wrong with the home made tool to find TDC. just be careful with it. the bolt only needs to be so long as to reach the center approximately. then it is best to remove all the plugs that way you can "sneak up on it" easier than if the plugs were installed. The tool will find TDC approximately to within 1 or 2 degrees. So its not for a ultimate engine build but good enough for most. {things like piston offset and carbon buildup and deflection of the tool itself can skew the accuracy }. Most of all its used to verify the accuracy of the timing marks on the front of the engine. Good luck!
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
