It is currently Mon May 25, 2026 4:57 am
PostPosted: Thu Jul 16, 2015 3:38 am
How do you check if your ignition coil is ok?
If you use Pertronix electronic ignition can you use a particular coil that means you do not need to run the wiring through the ballast resistor, i.e. connect the two wires from the electronic ignition directly to the coil.
PostPosted: Tue Jul 21, 2015 10:56 am
What does your petronix instructions say? I glanced at several sets of instructions at their site & all said to:1) remove the ballast resistor, & 2) use a coil with the reccomended primary resistance (1.5ohms for V8, 3.0 for 6 or 4 cyl.)
Your stock coil will probably work ok with the ballast removed but might (eventually) overheat if the petronix unit runs high dwell at idle.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Tue Jul 21, 2015 3:05 pm
The pertronix 1 needs either a 3 ohm coil or stock coil with ballast.
The stock coil without ballast will burn out the pertronix.
