It is currently Thu Jul 16, 2026 8:30 pm
PostPosted: Tue Jul 21, 2015 7:55 pm
Car Model: 1964 Valiant
I removed the steering wheel and the turn signal switch from my '85 D150. How do I remove the lock cylinder?
PostPosted: Tue Jul 21, 2015 11:42 pm
Do you have the tilt column? If so I cant help but if not there is a stering wheel lock that needs removed and then there is a pin holding the tumbler in. put your key in the lock, push in the pin and it should slide out. But again I dont know about tilt columns......
~Nic
PostPosted: Thu Jul 23, 2015 9:27 pm
The FSM has been very helpful. I had to remove a snap ring.
