D150 remove ignition lock cylinder
https://slantsix.org/forum/viewtopic.php?t=58109
Author:  Tim Keith [ Tue Jul 21, 2015 7:55 pm ]
Post subject:  D150 remove ignition lock cylinder
I removed the steering wheel and the turn signal switch from my '85 D150. How do I remove the lock cylinder?
Author:  Nicademas [ Tue Jul 21, 2015 11:42 pm ]
Do you have the tilt column? If so I cant help but if not there is a stering wheel lock that needs removed and then there is a pin holding the tumbler in. put your key in the lock, push in the pin and it should slide out. But again I dont know about tilt columns......
Author:  Tim Keith [ Thu Jul 23, 2015 9:27 pm ]
The FSM has been very helpful. I had to remove a snap ring.
