It is currently Fri Nov 20, 2026 1:03 am
 Post subject: Radiator compatitbility
PostPosted: Fri Jul 24, 2015 6:11 pm
Got the truck running.
Started to overheat. Pulled the thermostat even though it is new. Still overheating
Water pump is working.
Truck sat for 15 years. Wasn't the coolest running truck when it was parked
Now my question...
Are the truck and car radiators the same for the slant?
I was looking at this radiator:
http://www.genesisautoparts.com/product ... oCQ_jw_wcB
1975 Dodge D100 Utiline
Slant 6, Super Six, Weber 38, 727
Repair work in progress. :)
PostPosted: Tue Jul 28, 2015 12:49 pm
I was using a truck rad in my 67 until I found a volare in a u-pull-it yard with an 18" rad and shroud.
PostPosted: Wed Jul 29, 2015 4:51 pm
Can't say for sure if it'll fit, but that's a pretty decent price. If you measure, measure, and measure again before ordering you'll save some heartache. Been there, done that. The V8 water neck is on the wrong side, so make sure it's for a slant. But it can be made to work with the right hoses in a truck. I'm running a radiator from a D350 wrecker and it bolted right in, just needed a universal upper hose, the acordian looking one.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 107 guests
