It is currently Sat Nov 14, 2026 1:34 pm
PostPosted: Fri Aug 07, 2015 4:10 pm
Is there a correct sequence when connecting the battery cable to the starter motor - battery cable first then the other wire, or does'nt it really matter?
PostPosted: Fri Aug 07, 2015 4:11 pm
Doesn't matter, because the battery negative cable has been removed from the battery before you started the job.
