| Correct way to connect wires to starter motor https://slantsix.org/forum/viewtopic.php?t=58198 |
| Author: | crickhollow [ Fri Aug 07, 2015 4:10 pm ] |
| Post subject: | Correct way to connect wires to starter motor |
Is there a correct sequence when connecting the battery cable to the starter motor - battery cable first then the other wire, or does'nt it really matter? |
| Author: | SlantSixDan [ Fri Aug 07, 2015 4:11 pm ] |
Doesn't matter, because the battery negative cable has been removed from the battery before you started the job. |
