It is currently Tue Oct 13, 2026 8:52 pm
 Post subject: Junkyard find
PostPosted: Fri Sep 11, 2015 7:30 pm
Found a 87 D150 today with the radiator missing at a nearby junkyard. It has a/c p/s and p/b. And a much needed but unknown condition A904 transmission. I want to know if these components will fit in and on my 80 d150 with my 76 SL6 engine.
PostPosted: Fri Sep 11, 2015 7:37 pm
If the 87 truck is a slant six, then YES! All of the above will bolt right in to your 80 truck. Sounds like a good score!Maybe buy the whole 87 truck and swap radiators with your truck?
PostPosted: Sat Sep 12, 2015 5:44 am
I am using a new universal radiator in my truck. All I did was put a 2x4 under it to make sure it wasent resting on the cross support and then i drilled the our holes needed to mount it.
~Nic
PostPosted: Sat Sep 12, 2015 6:02 am
I'm using a big fat 4 pass radiator from a D 350 wrecker, and it bolted in using the factory holes. You're good to go.
PostPosted: Sat Sep 12, 2015 8:45 am
I thought '86 was the last year for the slant six? After that they launched the 3.9L with the new Dakota, and started using it in Rams as well?
PostPosted: Sat Sep 12, 2015 9:16 am
87 was the last year for installation of the slant in new vehicles.
PostPosted: Sun Sep 13, 2015 5:51 am
Thanks for the clarification :D
PostPosted: Sun Sep 13, 2015 7:59 am
My 87 D100 is a factory slant.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
