It is currently Tue Oct 13, 2026 12:10 am
 Post subject: wiesco pistons
PostPosted: Fri Sep 11, 2015 4:39 am
just searching and it seems the 3.5" bore piston are not available just the 3.42" and 3.44" ??
PostPosted: Fri Sep 11, 2015 6:43 am
I hope they will do more in the future as well. I bought 3.484 thinking I'd use the 3.503 for a rebuild.
Rick
PostPosted: Fri Sep 11, 2015 9:33 pm
I would try calling Wiseco or Campbellenterprises(.com) on the phone.
PostPosted: Sat Sep 12, 2015 3:49 pm
I forgot Cambell Enterprises thanks Lou
PostPosted: Sat Sep 12, 2015 6:39 pm
Are you ordering 1 or 6?
Part # might have changed. . I just ordered one from summit racing. Com in April. . It was at my house in 1-2 days.
PostPosted: Sat Sep 12, 2015 6:53 pm
I will have to dig up the receipt and post the new part#.. it was for a single. . Not the set.
PostPosted: Sat Sep 12, 2015 6:54 pm
6 going to do a low comp bottom for my drag car.
PostPosted: Sat Sep 12, 2015 7:39 pm
They seem to be avail. indvidually from the source..
http://wiseco.com/ProductDetail.aspx?ItemID=5112A104
You must be using custom rods to get low comp.
I will dig up the alternative part# when I get home.
PostPosted: Sun Sep 13, 2015 5:29 am
Terry,
Try buying them Here:
http://www.wiseco.com/ShoppingCart.aspx
Or calling them too
This is the part # I used in June 2015 - 5112H104 This seems to be unavailable now,
Bu the old 5112A104 Part # is available. I do not see the Set available. You might have to order six individual pistons.
I am sure if you call them you can get soomething sorted out.
Good luck Greg.
PostPosted: Sun Sep 13, 2015 4:05 pm
no Greg, going to use stock 225 rod which will give me 7.1/1 compression. I am at 8.1/1 now.
Users browsing this forum: Amazon [Bot] and 19 guests
