It is currently Fri Nov 20, 2026 12:41 am
PostPosted: Mon Sep 28, 2015 7:01 pm
Someone decided to put dirt inside the727 and it's on everything most internal parts have some sort of dirt on them. How can I clean this dirt off? Can it be hot tanked like a engine?
PostPosted: Mon Sep 28, 2015 11:19 pm
Loose dirt? Caked on crusty baked on dirt? Are you rebuilding the transmission (a very good idea if it has had dirt in it)?
A rebuild will have you disassembling everything anyway. Put the parts in a parts washer or scrub them with brake cleaner and a scrub brush if they are really dirty. The case can be pressure washed while it is empty.
PostPosted: Tue Sep 29, 2015 6:33 am
loose dirt and yes its going to be rebuilt. well it already was just was leaking fluid from a hole in the cooler line and I thought it was the shift shaft seal. so I want to clean it and re assemble might save money as apposed to buying 1.
