It is currently Fri Nov 20, 2026 3:07 pm
 Post subject: vacuum advance
PostPosted: Sat Oct 17, 2015 7:12 am
I have, here, an 1984 D150 with a slant in it. The distributor has no vacuum pod on it. I'm assuming the advance must be electric some how.
Also I cannot find a vacuum diagram on the web for this distributor and engine combination.
PostPosted: Sat Oct 17, 2015 10:26 am
No vacuum advance distributor is part of Lean Burn system. Additional advance over mechanical was controlled by Lean Burn computer.
Take a look at your carburetor for a ported vacuum tap, it sees vacuum above throttle plates, not manifold vacuum below throttle plates.
Take a look at the Lean Burn removal article here for better understanding of your situation.
