It is currently Sun May 31, 2026 4:51 pm
 Post subject: Valve cover sucks
PostPosted: Sun Oct 11, 2015 2:56 pm
I was replacing a leaking valve cover gasket today and also playing with the carb. I had the air cleaner off and the breather out of the valve cover. the engine was idling and I put my hand over the hole for the breather and noticed it had vacuum is this right?
my first 6 1973 Plymouth DusterImage
PostPosted: Sun Oct 11, 2015 3:09 pm
That's good.
It means you don't have excessive blow-by, as the PCV system can handle what is produced.
PostPosted: Sun Oct 11, 2015 3:25 pm
Ok that makes sense I did not even think about the PCV valve. Thank you.
