| Valve cover sucks https://slantsix.org/forum/viewtopic.php?t=58524 |
| Author: | 73dust225 [ Sun Oct 11, 2015 2:56 pm ] |
| Post subject: | Valve cover sucks |
I was replacing a leaking valve cover gasket today and also playing with the carb. I had the air cleaner off and the breather out of the valve cover. the engine was idling and I put my hand over the hole for the breather and noticed it had vacuum is this right? |
| Author: | emsvitil [ Sun Oct 11, 2015 3:09 pm ] |
That's good. It means you don't have excessive blow-by, as the PCV system can handle what is produced. |
| Author: | 73dust225 [ Sun Oct 11, 2015 3:25 pm ] |
Ok that makes sense I did not even think about the PCV valve. Thank you. |
