It is currently Thu May 07, 2026 6:13 am
 Post subject: 3 speed=4 speed??
PostPosted: Fri May 30, 2003 11:00 am
Is there any truth to what I have heard that the 3 spd slant bellhousing is the same as a 4 spd? I was just curious, since my car has a 3 spd, and going to a 4 spd would make more sense for me than sticking an automatic in the Dart.
PostPosted: Fri May 30, 2003 1:06 pm
Depends!
My 68 \6 barracuda had a 3 speed and the bellhousing would not accept a 4 speed. The mounting surface was too small top to bottom, the bottom bolts holes on the four speed were below the mounting suface. I went back to the junk yard that I pulled the OD 4spd from and got the bellhousing that was on that \6. It had several mounting patterns including one for the 3spd I had as well as the one for the 4spd.
I would assume that at some point when the OD 4spd became more common behind \6's the bellhousings were consolidated
Dave Clement
68 Barracuda (Hot-Rod \6)
http://mysite.verizon.net/vze4pgxf/
 Post subject: 6 into 2...
PostPosted: Fri May 30, 2003 2:18 pm
Dave,
How do those headers work for ground clearance and starter clearance? I like your Barracuda, and think it's a sweet ride, but I have been dying to ask you about those headers since I first saw pics of it. Also, what brand are they?
Thanks,
Steve Martin
 Post subject: Sometime about 1974....
PostPosted: Fri May 30, 2003 3:54 pm
Sometime in the last run of mopars circa 1974, they started the consolidation, though like the proliferation of small bolt pattern 9" drums some 3 speeds got the 3 speed only bellhousing, but some cars did get a dual pattern 3/4 speed bellhousing, by 1975 mopar switched over to the A-833 O/D and all the slant bellhousings for manual trannies are dual pattern (haven't really seen any 1975+ slant six 3spd applications, but there must be some out there somewhere...)
Is your tranny one of those peanut box column shifted 3 speeds?
 Post subject: 3 on the tree
PostPosted: Fri May 30, 2003 7:45 pm
Yep, it's the small 3 on the tree setup.
 Post subject: Re: 6 into 2...
PostPosted: Sun Jun 01, 2003 7:01 am
Dave,
Steve Martin
Absolutely no starter clearance problems. The number six tube you see in the picture looping way over gives you all the starter clearance you need. I do think it might interfere with a power booster though.
Like most headers they take away form the ground clearance but the fact that they are dual outlet it's less than a 6 into 1 header. In normal driving I have no issues. I do need to slow way down over speed bumps but otherwise that's the only issue I have had.
The headers are Hooker but I do not think they make the dual outlet ones anymore.
