It is currently Fri Nov 13, 2026 4:17 am
PostPosted: Fri Jan 08, 2016 3:58 pm
I have original 66 slant 6 dart, with the 13 inch wheels. 5 bolts, 4in pattern.
Would like to move up in size, but I dont want to do any mods, just new wheels and tires.
I have 9in drums btw,.
If possible I would like to reuse my current hub caps?
So if I go to junkyards or search Craigslit, what numbers am I looking for?
help?
66 dodge dart 270, 225ci, 3.7l, L6
 Post subject: It's...
PostPosted: Fri Jan 08, 2016 4:30 pm
Pretty limited to:
Stock steel wheels at 14x5 (+/-)... searching for Mopar SBP ("small bolt pattern"), or 5x4 (5 lugs on 4" center circle pattern)
If dog dishes you should be able to use them, if full wheel covers, they may not fit...
Some Ford aftermarket aluminum rims were in this pattern and 14x6 or 14x7...(not easy to find as much any more)...
If you are rolling in the coin, you can order a set of Rallyes or new steel rims in this bolt pattern in custom sizes from one of the wheel vendors like Cokers, etc...
Too bad you weren't looking 3 years ago when I cleaned out my shop, I took 8 late 60's 14" steel rims to the scrap yard, just because I no longer had a vehicle in that pattern and with everyone going to disc brakes and mopar LBP no one wanted them....
:cry:
 Post subject: aftermarket choices...
PostPosted: Fri Jan 08, 2016 6:37 pm
...are pretty much Cragar SS and Ansen slots. And those are getting harder to find for small bolt pattern.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Jan 09, 2016 9:47 am
I am not able to afford any new stuff, so craigslit or junkyards is my current plan of action. So if I can find the 5 lug small bolt pattern (easy to measure), then make sure it is 14in? I assume it will be stamped on the wheel? Then what about the width? What is width options that wont require me to add spacers, and also insure that the tire doesnt rub on the fender etc...
I dont have Dog dish caps, I have the Dodge Dart ones that cover the entire wheel. Sounds like those are specific to size of wheel.
great info guys, keep it coming.
PostPosted: Sat Apr 16, 2016 4:07 pm
Any Mopar small bolt pattern 14" wheel will have the correct offset, and the only width options would be 4.5 or 5.5. So anything you can find will work. Yes, full wheel covers are either 13 or 14".
Max
1967 Barracuda Convertible
 Post subject: 14 " steelies
PostPosted: Sat Apr 16, 2016 7:18 pm
Where in so cal are you? I got a set of stock 14" wheels and I'm in Oceanside, CA. If your interested please let me know
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Sun Apr 17, 2016 5:55 pm
I would think Most FWD mopar with the 5 o 110mm Wheels would fit as well now backspacking / offset might be an issue, but You could get some pt crusier wheels and see what will work.
PostPosted: Fri Apr 22, 2016 10:15 pm
Car Model: 1964 Valiant
Mopar Set of (4) Rims & Tires, A-body Small Bolt Pattern
http://killeen.craigslist.org/wto/5494970406.html
